How do you disable the seatbelt chime on a 2007 Toyota Camry?
Old Oct 2, 2008 | 10:13 AM
ct63366's Avatar
Default How do you disable the seatbelt chime on a 2007 Toyota Camry?
How do you disable the seatbelt chime on a 2007 Toyota Camry? I ALWAYS wear my seatbelt ! ! !, but if I have stuff in the front passenger seat, it'sbuzzin away.. Iwill NOTstrap in groceries.. Thanks for your time...
Chris
Old Oct 2, 2008 | 10:58 AM
Default RE: How do you disable the seatbelt chime on a 2007 Toyota Camry?
One issue is the various seat switches and sensors are tied into a computer linked to the airbag system. This is not a simple system.
Typically there is a switch inside the female bucket that closes when the male portion is inserted. If you do start digging around looking for this switch remember the seat also has an occupant clasification sensor, perhaps built-in airbags and other wiring.
The easiest fix is to buckle the belt. Might try finding just a male buckle end piece that can be stuck into the slot. In either case if the airbags do deploy in an accident the passengers side will most likely also go off as there is weight on the seat.
Your question has been asked before but to date have never found a satifactory solution to this problem.
Old Oct 2, 2008 | 07:34 PM
flyerI's Avatar
Maybe put the groceries in the rear floorboard where they are less likely to hit you in the event of an accident.
bwdebeck
Jun 24, 2020 09:26 AM
tri1968
Jul 23, 2012 10:14 AM
ct63366
Oct 2, 2008 10:58 AM
nursecamry
Apr 21, 2007 11:13 PM
teach
Jan 14, 2006 09:33 PM
