Sponsored by:
Sponsored by:
2000 Camry, 4cyl, sluggish at take offs
Old 08-29-2015, 07:17 PM
Kscott1994's Avatar
Default 2000 Camry, 4cyl, sluggish at take offs
Just bought a 2000 Camry with 150k miles 4cyl. Drove great for a week but now wants to cut off at stop signs or stop lights and is very sluggish when you start off. You press the gas and it will not move for several secs. Once going it drives good. When to advance auto parts and p0440, p0441, p0446 and p106 are the codes. Any help appreciated.
Old 09-02-2015, 03:52 AM
Totoro Camry's Avatar
Had similar problem with 02 4cyl, mine would stall without fuel tho, try cleaning Maf and giving it some drive cycles
Old 09-02-2015, 07:47 PM
This car has a MAP sensor (P0106).
Check the hose between sensor and intake for leaks, damage, etc. Make sure the sensor is securely plugged into the cars wiring. If all is OK, change MAP sensor. Try auto salvage yards or Ebay for reasonable prices on used ones.
The other codes are related to the EVAP system and typically don't cause drivability issues.
tight budget
01-12-2012 07:45 AM
rusty-c
09-26-2011 12:10 PM
Gellin
11-21-2007 06:39 PM
GroundAndPound
11-11-2007 02:57 PM
brasur0104
06-08-2007 10:06 PM
Quick Reply: 2000 Camry, 4cyl, sluggish at take offs
