Browse all: Intake and Exhaust System
- Toyota Camry 6th gen How to Replace Oxygen Sensor
2000 camry- oxygen sensor?
My 2000 camry is in the shop right now (meineke) and it appears that the oxygen sensor needs to be replaced. How easy would this be to do myself? Anyone have any idea what kind of cost I am looking at?
Thanks in advance.
Thanks in advance.
A few items one needs to know. What engine model, was the car built to California or 48 state emissions standards (there should be a sticker under the hood stating which) and what sensor (the car has more then one).
You can replace the sensor yourself easy enough. You may need a special socket that makes removing the sensor easier. Available at low cost from auto parts or tool stores.
For an indication of prices research your required part at the site below:
RockAuto Auto Parts
Suggest using a Denso brand non-universal sensor or going to the dealer (which will be more expensive). Other brands and types may work but some times cause issues with the check engine light coming on.
RockAuto Auto Parts
RockAuto Auto Parts
RockAuto Auto Parts
Thanks for the info.
Most likely then a California emission car. This engine has more then one sensor.
If you know which sensor you can buy the correct part and install it yourself. The computer readout of codes will determine which sensor it is, assuming it was an AF sensor caused the check engine light coming on.
Suggest doing an internet search on replacing AF sensor on a 5SFE engine. This should provide hits, perhaps some with photos to give you a better understanding of the repair.
If you shop around for prices, depending on which sensor is bad the cost will range from $70-110.
Dhomsey
09-16-2013 10:42 AM
appleredcamry
06-14-2009 07:06 AM
pdiddy
05-09-2009 04:56 PM
