How do I install 2000 Toyota Camry 2.2 L4 front "upstream" oxygen sensor
Old Sep 6, 2013 | 04:06 PM
Dhomsey's Avatar
Default How do I install 2000 Toyota Camry 2.2 L4 front "upstream" oxygen sensor
I have the check engine light on. show front sensor is bad.. found the part on ebay for $48. anyone with a 2000 camry know how to replace this. Do you take out the drivers seat or go under the car? Is it hard to see/ reach?
Old Sep 6, 2013 | 05:11 PM
Upstream sensor is first sensor on exhaust system coming off the cylinder head. It screws into a flange on the exhaust system. You should be able to see to when looking at the exhaust system.
The best method of removal is to obtain an 02 sensor socket having a cut out for the wiring to clear the socket when installed.
Old Sep 6, 2013 | 06:27 PM
Dhomsey's Avatar
Default Do you know how to get to the sensor?
can you reach it under the hood, under the car or under the seat?
Old Sep 7, 2013 | 12:16 PM
Under hood.
Look at the exhaust system bolted to the cylinder head. Follow the individual exhaust pipes down to the where their join into one then look around for the O2 sensor screwed into what looks like a large pipe or large can area.
Old Sep 15, 2013 | 04:08 PM
Dhomsey's Avatar
Default Front fuel/oxygen 2000 camry sensor "EASY" install
2000 Camry..(FRONT sensor) PART #8946506010 for 97 98 99 00 Toyota Camry Solora 2.2 L4 Oxygen Sensor O2 $42.00 (on ebay) located under hood right in the front. sprayed lubricant on sensor bolt, unsnapped wire, ran wire through 7/8 inch circle wrench, turn towards you to loosen came right off. took about 5 minutes to replace. TOYOTA WANTED $350.00 TO DO THIS!!
Last edited by Dhomsey; Sep 16, 2013 at 10:56 AM. Reason: heres a pic.. disconnect wire, run wire through a 7/8 circle wrench to sensor. turn toward you to release
Old Sep 16, 2013 | 10:42 AM
Dhomsey's Avatar
https://mail-attachment.googleuserco...JgBTu5DQyCXl3w
tvsdprasad
May 20, 2015 04:06 AM
MomInCA
May 24, 2011 04:06 PM
peterliu2000
Aug 11, 2010 11:15 PM
appleredcamry
Jun 14, 2009 07:06 AM
