Sponsored by:
Sponsored by:
06 Camry front turn signal bulb
Old 09-04-2019, 05:05 PM
mkbjersey's Avatar
Default 06 Camry front turn signal bulb
On my 06 Camry the front turn signal bulb is a dual element type bulb (3457 amber). The bulb only illuminates one of the elements when flashing. Should the other element be illuminated when my headlights are on? In other words, with my headlights on the turn signal bulb will be on "low" and when flashing it will be brighter.
Old 09-04-2019, 09:11 PM
Front turn signal only uses one element.
Old 09-05-2019, 08:45 AM
mkbjersey's Avatar
Thanks for the reply Toyomoho! Since Toyota wired it that way can I assume that installing switch back LED bulbs is precluded unless I modify the wiring to make the second element hot when the headlights/running lights are on? I really like the JDMastar LED's. Has anybody made this mod before?
Old 09-05-2019, 02:09 PM
Look for a dual element LED bulb that states it replaces the bulb part number currently installed.
Old 09-05-2019, 02:18 PM
mkbjersey's Avatar
Will do and thanks for the reply and help.
ShunDoe
02-22-2016 01:24 PM
rangermenace
01-17-2013 08:33 AM
dreis13
03-26-2008 05:47 PM
cedric
04-13-2007 02:12 AM
yengee
04-10-2007 07:15 AM
Quick Reply: 06 Camry front turn signal bulb
