98 camry
98 camry
I jumped the tc and e1 in my camry with and without short pin.
With the pin in I have a code 43 for trac off.
With pin out I was able to retrieve codes for the abs, I ended up getting codes
21,22,23,24,25,26,27,28nd31 for the abs.
Also my airbag light is on.
Am I most likely going to have to replace the abs pump and right front sensor for my system?
Does anyone have knowledge regarding the codes and problems I am having with my camry?
wire bridging only lets you know what codes are present
with the air bag and abs faults
you will need the proper obd1 or an obd2 diagnostic reader
to find where the fault is .., the fix ,and clear those codes
i checked other toyota forums and they didnt have the answer to code 43
toyota code 43.. says is starter signal circuit........not very helpful
