Sponsored by:
Sponsored by:
clutch pedal won't release, master cylinder?
Old 01-11-2007, 05:57 PM
jselse01's Avatar
Default clutch pedal won't release, master cylinder?
[align=left]I have a '96 Camry 4 cyl. When driving up and down a lot of hills my clutch pedal sticks and I cannot shift down or up. If I pull over and stop the car for a few minutes, the pedal works again until I hit the hills. I have plenty of fluid. What could it be?
[/align]
Old 01-12-2007, 01:55 PM
geokor's Avatar
Default RE: clutch pedal won't release, master cylinder?
Try bleeding the system. There may be an air pocket that is moving around the line/ cylinder. Make sure you jack up the front end to simulate the angle of the car going up hill. That should make the air bubble draw to the cylinder and close to the bleed vavle.
J2Performance
01-25-2008 11:53 AM
J2Performance
12-17-2007 03:59 PM
J2Performance
12-13-2007 11:55 AM
J2Performance
12-13-2007 11:46 AM
J2Performance
12-13-2007 11:25 AM
Quick Reply: clutch pedal won't release, master cylinder?
