Sponsored by:
Sponsored by:
Drumming Noise from front left wheel
Old 09-19-2009, 04:27 AM
benjamin2010's Avatar
Default Drumming Noise from front left wheel
Hello
Our Toyota Camry has a drumming noise coming from the left front wheel while the car is moving
you can feel it when you are the front passenger
What could it be?
Is it a rotor? or something else?
cheers
Old 09-19-2009, 07:07 AM
flyerI's Avatar
Could be a wheel bearing or a bad tire. What speed do you begin feeling/hearing this? Does it get louder the faster you get? If it happens at slow (5-10mph) then it is probably in the drive line, maybe a bearing. If it begins happening as spped increases it would point towards at tire. Are your tires worn? Could be a cord seperating or uneven wear. Check the tread to see if they are worn even with no scalloping. This is not conclusive but just the direction I would look.
FERGI
03-25-2011 05:04 PM
Shawn98408
10-18-2010 08:58 PM
mikeynavy1
09-16-2006 03:23 PM
Quick Reply: Drumming Noise from front left wheel
