Sponsored by:
Sponsored by:
Old 08-28-2015, 11:44 AM
How-Tos on this Topic
Browse all: Wheels and Tires
Print Wikipost
Spark Plug Wire Install gone wrong...!
Old 01-24-2007, 09:12 PM
nodrogkam's Avatar
Default Spark Plug Wire Install gone wrong...!
OKay help. - this would be great if you had photos or went out and checked your car or have a haynes manual handy.
Car is a 1998 Camry XLE V6 (1mz-fe)
First and foremost i would like to say that I am a dumb ***.
I had some time after classes today to fiddle with this lil project.
Second -
I had labeled the wires (even though they were already labeled), but thinking i was hot stuff i went ahead and just took pictures and pull everything out at once.
Heres my issue, i don't know which plug corresponds to which coil.
Here's what i mean:
i hope that the numbers i put on the wires are the right numbers, because it doesnt make sense to me...i thought they would be in order.
If someone could trace the wires back to the rear and tell me which plug hole they correspond to that would be great.
ie. wire 5 corresponds with hole 1 in rear (hole 1 being the one closest to the passenger side)
wire 1 corresponds with the hole 2 in the rear (hole 2 being the middle hole)
wire 3 corresponds with the hole 3 in the rear (hole 3 being the one closest to drivers ide/battery)
I did try to start up the car based on what i thought was right. It started strong then idled roughly. Of course i immediately shut off the car, but i'm sure i didnt do any damage...at least i hope.
Old 01-25-2007, 09:51 AM
pedro's Avatar
Default RE: Spark Plug Wire Install gone wrong...!
I'm not sure if this will help but the firing order is 1-2-3-4-5-6
from left to right as you face the engine from the front of the car,
1-3-5
2-4-6
I would think the coils would be numbered but their position should be a clue as to where the wires go.
Old 01-25-2007, 01:13 PM
nodrogkam's Avatar
well that's what doesnt make sense to me is that if that's the order then why don't the wires go in order? As noted in the photo the wires were numbered 5, 1, 3.
I can definately just plug them into the corresponding plugs in the rear but it just seems wierd.
Old 01-25-2007, 09:27 PM
pedro's Avatar
The firing order I gave was for each piston. Since I have a 4 cyl'd I can't advise how the coils are positioned andfired. Maybe someone with a V6 can send you a pic on how their setup looks. If you have a timing light you can at least check piston of #1.
Old 01-26-2007, 12:50 AM
nodrogkam's Avatar
thank you, problem was resolved today.
manty1
04-10-2013 04:54 AM
TonyJ
07-20-2012 12:14 AM
crazylove
06-20-2012 01:39 AM
tijuana_dude
11-17-2010 03:40 PM
philip
01-16-2009 07:01 PM
Quick Reply: Spark Plug Wire Install gone wrong...!
