Headers, Intake, & Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Chugging after exhaust manifold replacement
Old 09-01-2015, 10:37 AM
Jocepi's Avatar
Default Chugging after exhaust manifold replacement
I just replaced the exhaust manifold on my 1998 Camry 2.2L California Standard. Now it idles rough and chugs at around 60-65 mph. THe mechanic said the O2 sensor can tend to foul when replacing the manifold, is this what is going on? Any help would be appreciated.
Old 09-01-2015, 10:53 PM
Did the problem occur after the manifold change?
Is the replacement manifold the same design as the original?
Was original sensor swapped to the replacement manifold?
Just changing a manifold should not cause issues.
Old 09-02-2015, 07:29 AM
Jocepi's Avatar
Same design manifold, the old O2 sensor was switched to the new manifold, and the chugging was not present before replacing the manifold.
Old 09-02-2015, 07:42 PM
If the check engine light is on, go back to the mechanic and have them output any trouble codes. The code(s) will be specific as to the problem area.
It could be the sensor is bad, is somehow not connected to the cars wiring, a sensor fuse blow (if sensor is heated) or the mechanic could have screwed up. Have the mechanic check things out and post back.
Issues with this sensor can cause your operational problems.
Steve P
03-31-2013 09:54 PM
rgus67
08-12-2012 12:20 PM
jimhey
11-28-2011 07:05 PM
Chugs
02-19-2010 02:43 PM
Marvel
07-13-2009 10:55 AM
Quick Reply: Chugging after exhaust manifold replacement
