2014 alloy wheels on a 2010 Camry
Old 08-23-2014, 11:07 AM
MaxChila's Avatar
Default 2014 alloy wheels on a 2010 Camry
I recently purchased a set of alloy wheels from a 2014 Camry to put on my non-alloy wheeled 2010 Camry. From my research it appears they should fit, except the wheels are bigger (17" compared to the original 16"). All other specs are inline with the old wheels (Number of Bolts, Bolt Pattern, Offset). I plan on buying new tires as well, but I'm still worried the actual wheel won't fit on the car or I overlooked something else (tire pressure sensor won't fit from the old wheels, etc). If anyone has experience with this let me know if you see any problems with this set-up.
Thank you.
Old 08-23-2014, 11:36 AM
17 inch rims where available as OEM for the 2010.
The tire pressure sensor mounts inside the stem hole in rim, should work OK. If concerned take replacement rim to whoever will be mounting the tires and ask.
Old 08-24-2014, 12:06 PM
MaxChila's Avatar
The tire pressure sensor was a big concern. I haven't got the wheels in yet but when I do I'll shop around for tires and go from there.
Thanks for your help.
Old 08-25-2014, 12:45 AM
Let us know how it pans out. I've got some factory Camry wheels that I want to put on my car just haven't had the time or the extra cash. Oh, the joys of home ownership!
Old 09-13-2014, 09:32 AM
MaxChila's Avatar
Everything worked out with the Camry wheels, they fit as expected and the tire pressure sensors got transferred from the old wheels with nothing additional needing to be purchased. They look pretty good too:
Old 09-14-2014, 02:05 AM
Very sharp! Looks great and thanks for posting an update and pic.
Bigasshammm
07-04-2010 06:11 PM
spark
06-09-2009 06:35 AM
No.11
03-15-2009 05:51 PM
SVThound
09-16-2008 07:38 PM
illmatic
03-22-2008 01:58 AM
Quick Reply: 2014 alloy wheels on a 2010 Camry
