2005 Camry right rear drum wont come off
Old Oct 1, 2014 | 06:55 PM
rapala13's Avatar
Default 2005 Camry right rear drum wont come off
I had a tire blow out, two nuts snapped off, custom rims came with car when I brought it, 12mm internal hex. I suspect they were overtorqued.
I loosened self adjuster star all the way, and the drum still wont come off, I have tried heat with propane torch where hub meets drum.
Any ideas? And no parking brake isn't on.
2005 Camry right rear drum.
Old Oct 1, 2014 | 08:07 PM
dirty hands's Avatar
this is a very common problem
it must be rusted on the hub centre good
heat at the hub centre and banging around the out side is the usual way
are there holes with threads on the drum it self near the hub on that one
other than the adjusting hole if so bolts can be used as a puller to get that drum away from the hub
if a real problem (brakes must be in a bad way to have to do this )
you could undo the brake cylinder itself enough to move the brake shoes closer and if no better
and drill out the brake shoe retaining pins from the back plate
no holding star or hex grub screw in the drum on these ---
you wont believe the things people tried and did or didnt work
a dremmel hole in the back plate -
3 pound sledge
remove the back plate and hub from suspension and drop from a height till drum pops off
One fellow persisted for four hours on one side
Old Oct 1, 2014 | 09:38 PM
rapala13's Avatar
I got it off using two M8 bolts. Removed all four bolts thru the hub to remove bearing except it wouldn't come off. Only the whole assembly including backing plate wants to come off.
Old Oct 2, 2014 | 01:19 AM
well done
check the drum does not have a lip at its edge (machine both drums if it does)
now that hub has to have new studs in (replace all five )
Cam2003
Jan 20, 2022 06:32 AM
Ninja122
Sep 28, 2016 07:56 PM
1989_Camry
Jan 10, 2015 02:51 PM
keystone1979
Jul 9, 2011 10:39 AM
grocerygettercamry
Apr 9, 2009 11:27 AM
