vibrations & noise from tires at high speeds
Old 10-05-2006, 05:53 PM
pinky's Avatar
Default vibrations & noise from tires at high speeds
Hello,
I have a 95 toyota camry. When driving on the freeway at high speeds (50 and up), there's a lot of noise and vibration coming from the right side of my car. It almost sounds like the wheels are wobbling. I just got my tires changed and aligned. I have also checked the tightness of the bolts. When I step on the brakes at these speeds, it heavily vibrates and the sound tends to get worse. What do you think it might be? Thank you very much for your help!!
Old 10-08-2006, 03:05 AM
TCG3's Avatar
Default RE: vibrations & noise from tires at high speeds
Pinky: I'm no expert but here goes... Make sure the parking brake is not on. Did this start only after the work was done? If so that work should be double checked. Other possibilities include worn out struts or very badly warped or cracked brake discs. My '94 is having the same problem and it appears to be worn struts. I have 175K miles and have only changed the front struts. ( I know, not good..) The noise in my car all comes from the rear. A (reliable) source thought it would be the struts. Good luck and let me know the result.
camry69510
07-28-2015 12:45 AM
buch75
11-09-2009 11:48 PM
pinky
10-05-2006 05:52 PM
marc780
04-10-2006 06:22 PM
Quick Reply: vibrations & noise from tires at high speeds
