2008 acv36r electrical fault
Old Oct 19, 2020 | 10:42 PM
Mat's Avatar
Mat
Exclamation 2008 acv36r electrical fault
We have an on going electrical fault when ignition is on or starting.
When we turn the key the accessories sometimes drops out including windows , radio, dash vacuum,etc.
If you ignore it after a while it comes good.
The other thing to do is turn it off and on till the fan / gauges start working.
also to mention some times when started and all is good and you go though the gears to neutral / reverse it can sometimes cut out. as above.
put in neutral and start again.
We thought we had tracked it down to a dirty fuse holder / carriers.
an auto sparky suggested it because there so much draw on start up there are 2 ignition relays,
When we tried the OBD diagnosis it didnt even show up ?
2008 sedan
ACV36R
Regards Mat
Old Oct 20, 2020 | 05:59 PM
Need more info.
When the key is turned to ACC exactly what specific items drop out?
When the engine dies what electrical items also drop out?
Does the dome light continue to work when any of the above happens?
charlieqf
Dec 19, 2010 07:23 PM
FerdiLu
Mar 26, 2009 04:56 AM
MichaelBe
Dec 17, 2008 04:35 AM
PaulAd
Dec 2, 2008 01:02 AM
johnsonbs
Jul 2, 2008 05:36 PM
