97-99 headlight questions
Old May 7, 2008 | 01:00 AM
mr.login's Avatar
Default 97-99 headlight questions
Hello everyone. Both of my parents drive Camrys. One is a 97, and the other is a 98. Both cars' headlights are badly stained from time and sun exposure. I've been looking at different options, such as: cleaning the lenses by wet-sanding with 2000 grit sandpaper, buying new headlights on eBay, and the purpose of this post, wondering if the 2000 Camry headlights fit. The 2000 headlights are clear, and as you probably know, the 97-99 are hazy with gridlines, even brand new. So, would the 2000 lights just bolt right in spot? They look almost identical in shape.
Thanks,
Greg
Old May 7, 2008 | 01:39 AM
Default RE: 97-99 headlight questions
The headlight appears to run between years 1997-99, see link below:
http://www.carpartswholesale.com/who...y-9439205.html
The gridlines help defuse the light.
If the lens just has surface haze and and yellowing you can try wet sanding (use water) and 2000 grit sand paper, then a rubbing compound and a paste wax. Rub back and forth across the lens rather then a circle.
A Google search should turn up other methods of cleaning these lens.
Old Jun 1, 2008 | 12:41 AM
boogz's Avatar
There is also a product that you can pick up from Kragen, Pepboys, etc. that has become pretty useful for cleaning lenses. It's called PlastX. I've used it myself and I am satisfied with the results.
rikkyjay
Aug 13, 2015 08:46 PM
bOosty
Aug 15, 2006 05:09 PM
qwe76101
Jun 22, 2006 09:19 PM
03Fooshii
Feb 23, 2006 12:28 AM
Agnes the Camry
May 26, 2005 03:12 AM
