Old Aug 27, 2015, 11:17 AM
How-Tos on this Topic
Browse all: Lighting
Print Wikipost
HID Xenon 2007 Camry SE
Old Feb 9, 2007 | 12:59 PM
  #11
Amoore1011's Avatar
Default RE: HID Xenon 2007 Camry SE
The low beam projector bulbs for the 07 camry are H11
I thought they were H7 which would have been perfect for my oem xenon retrofit but now have to get aftermarket bulbsI am pissed about that...I really have never heard of H11 Projectors as low beams...hahah
What i am going to be putting in my 07 now is Hella Gen3 ballasts and after market 4300K H11 bulbs...should look pretty much exactly the same as oem setups that come stock on cars....i will post pics once i get everything setup
Old Feb 9, 2007 | 03:26 PM
  #12
nodrogkam's Avatar
http://www.sylvania.com/ConsumerProd...lacementGuide/
everyone bookmark that website.
Old Mar 14, 2007 | 10:11 PM
  #13
JPTILLMAN's Avatar
DOES ANYONE KNOW WHERE THE HARNESS IS LOCATED TO INSTALL THE HID KIT IN 2007 CAMRY
Old Apr 7, 2007 | 06:23 PM
  #14
Amoore1011's Avatar
You would have to build your own harness and hook it directly up to the battery and then have a relay hooking up to the factory headlight plug so you are able to the turn them on. Here is a diagram...
[IMG]local://upfiles/2110/137F2F23B00C48D5A227B0F1C98380D5.jpg[/IMG]
Old Apr 8, 2007 | 04:15 AM
  #15
nodrogkam's Avatar
http://www.sylvania.com/ConsumerProd...de/default.htm
you will want to bookmark that website.
your SE has projectors right? never install HID's into a vehicle without projectors. That would be illegal in a few states, as well as dangerous to other drivers (you included).
Old Jun 23, 2007 | 02:58 PM
  #16
Redbull's Avatar
Does any one already install the HID in the 07 Camry? Please show some photo (engine bay). Does the conversion kit effect the computer, light indicator on or need to disconnect the day time running light? Any side effect?
Which brand is the best for Camry? Thank you very much!!
Old Jul 14, 2007 | 04:33 PM
  #17
hungdang80's Avatar
thanks dave for the help. i successfully installed my HIDs in my 07 camry and they look terrific. I didn't bother messing with the high beams since i barely use them, so i kept them stock. And sorry for such a late "thank you".
I have another question now. I'm thinking of also replacing my fog lights with some xenon bulbs. Would I also need a ballast to go along with each bulb? or can i just throw on some xenon bulb and be done with it? something tells me I do need it, but I wanted to make sure first.
Old Jul 20, 2007 | 09:18 PM
  #18
Redbull's Avatar
I changed my factory fog light bulbs to H11 SERIES: PIAA H11 IONCRYSTAL YELLOW . Its look really cool.
Old Aug 6, 2007 | 06:03 PM
  #19
iantrack21's Avatar
Ok so Im in the process of installing HID's in my car. This is what Ive found out. A few tips to sort of know;
1. HID's don't mean your high beams wont work, just that your normal lights will now be brighter than your High beams so its pointless to use them. You can though get HID's for your high beams as well and complete the entire process but that just seems over kill unless you're taking the camry to the wilderness.
2. The camry has NOTHING to help with HID's. I mean that you have to mount the the ballasts yourself somewhere in the engine compartment. Luckily for camry owners excess space under the hood is plentiful and you should have adequate room.
3. THE MOST IMPORTANT TIP!! I can't stress this enough; search and search for a plug and play type system. Otherwise you will have to do some serious wiring from that car's power source to the lights to get your system to work. Also once you o get your kit in don't touch the bulbs with your hands. Use gloves. These bulbs are super sensative and will blow if there is any kind of transference of oil from your hands. Other than that you should be ok. Good Luck!!
Old Feb 7, 2011 | 09:56 AM
  #20
lacky's Avatar
I've heard that installing HID's without having projectors blinds other drivers on the road since you don't have the "cutoff" that projectors provide.
Any truth to this??
