Browse all: Exterior Guides
- Toyota Camry 4th gen How to Remove Fender
Step by step instructions for do-it-yourself repairs
Removing rt fender
I need to remove the rt fender on my '96 Camry to bang out a dent. Is there anything unique about removing it or is it as easy as removing the inner fender and removing the bolts? Thanks!
sorry, Ive tried to post a response many times, but this forum has been experiencing some technical difficulties. remove the bolts along the top (under the hood), along the side (along the door hinge) and underneath (in front of the tire), then unscrew the plugs that hold the wheel well liner too unsap it from the fender and you should be good to go. Hope this helps
no problem man, I should also warn you that alot of those plastic screw plugs that hold the wheel well liner in place will probably break upon removal. You should be able to get them from autozone for really cheap.
Remove the inner fender from the hood first. you'll have to remove some parts that will block its way, then there would be no prob removing the outer one. Good luck!
________________________________________________
Autopartswarehouse.com rocks!
pauper
May 10, 2013 08:39 PM
Suavelp2
Jul 2, 2009 01:38 AM
syadav
Aug 24, 2008 10:35 PM
