1998 Radio Removal
http://support.diceelectronics.com/f...ta_install.pdf
Instructions for Dice Elec. Ipod thingy. But it shows you how to remove the radio for a more modern camry.... Hope it helps though
If it's like my 99, which I think it is. you need to pop the black surrounding off....mine was alittle difficult...but it popped out with some effort...and then I think there are maybe 4screws holding the stock headunit in place.
hope that helps
Josh
hope that helps
Josh
use a flat head and pop out the black surrounding trim of the radio. there are clips that go alla round the trim. you should probably remove the ash tray before hand.
once you get part of it off you'll know how to do the rest =) try not to break clips!
i've removed mine countless times and i've only broken one. hehe.
