2001 Toyota radio wiring.
Old 08-05-2018, 03:37 PM
Justin King's Avatar
Default 2001 Toyota radio wiring.
Hello all, I'm trying to replace the radio in my car. I bought a cheap $20 radio for Wal-Mart since I just want my radio to be very basic. The wiring rn is my biggest issue. If tried all the recommend harnesses but they don't fit so if resorted to splicing the wires and connecting them straight into the new radio. The problem occurs when all the diagrams say " pink and purple" for the stock wires. My car does not have these wires but in stead has a red wire with a blue line and two green wires I need help!!!
Old 08-05-2018, 08:30 PM
Did the old radio have a remote amp?
Old 08-06-2018, 10:55 AM
I don't think so. As far as I'm everything is stock.
Old 08-06-2018, 11:42 AM
There should be a large sticker on the old factory radio. Find the radio number and post back.
It might start with numbers 86120 or such followed by 5 letters/numbers.
Old 07-22-2021, 09:37 PM
Ojdabb's Avatar
mine is Model number 86120-0c040
I am having the same problem anything will help
Old 07-23-2021, 12:30 PM
Does the radio have one wiring harness plug or two?
Old 07-23-2021, 07:54 PM
Ojdabb's Avatar
it has 2 ports but only one had a plug connected
Old 07-24-2021, 12:36 PM
Plugs like in the link below: If so which plug is used.
https://pinoutguide.com/Car-Stereo-T...t_pinout.shtml
Old 07-24-2021, 06:30 PM
Ojdabb's Avatar
The plug previously used was the 20 pin connector
Old 08-04-2021, 09:11 AM
Ojdabb's Avatar
So, I have a breakthrough, instead of the 20 pin connector hooked to the stereo the wires you use for hooking up adapters are on the right there are 2 white clips and an adapter kit from Walmart was able to be plugged in and connected and it works! Thanks for your help!
Quick Reply: 2001 Toyota radio wiring.
