'21 Rear USB Cable/Port
I'd like to add the rear USB port that's offered by Toyota. I'm guessing along with it being installed at the factory it can also be a dealer installed item. I can't find this assembly anywhere.
Has anybody installed one or know where this item can be found? I really don't want to go with a universal one if I don't have to. It seems that the real OEM part would have the correct connector to plug in somewhere under the dash. I don't think it would be spliced into the harness.
I also wonder how it it's installed in the rear of the console. Does a hole have to be drilled or is there a removable panel that is replaced by the new one?
Thanks!
Thanks!
I found the installation instructions elsewhere and it's a fairly involved process in removing the various panels to get at the power source, which is under the dash. But with the cost of the part it's just a few more dollars extra to have them do it. I can let the tech worry about trying not to break a mounting tab on the trim!
camman
Dec 14, 2006 11:06 AM
