1997 camry v6
Old Jun 18, 2009 | 09:31 PM
camry34's Avatar
Default 1997 camry v6
How do u replace front door spaekers? thx in advance..
Old Jun 19, 2009 | 01:00 PM
nodrogkam's Avatar
I was about to say do a search but i guess things have gotten cleaned up around here. And apparently i've never taken photos of my speakers install in the front.
From memory, you need to first remove the screw behind the small cover where the handle to open the door is (from the inside). Then you must remove the handle cover. Easiest way to do that is to use a flat head and begin to gentry pry around the handle hinge area and it should pop out. There should be a few more screws around the entire door panel, below the side map pockets. After all the screws are removed, you will then proceed to pop the door off. there are various "clips" that you cannot see which the keep the inside panel attached to the door. Once these are popped off you need to lift the panel UP and off the window track. That's it.
lavalleemike
May 9, 2006 02:34 PM
FishyMan
Apr 4, 2006 08:45 PM
jeannekrieg
Mar 7, 2006 07:19 PM
crazybabyinky
Feb 15, 2006 05:09 AM
rsw0tet
Nov 11, 2005 04:24 PM
