Old Aug 26, 2015, 04:14 PM
How-Tos on this Topic
Browse all: Interior
Print Wikipost
2011 Camry LE Bluetooth
Old Oct 11, 2012 | 11:49 AM
mgeorgevich's Avatar
Default 2011 Camry LE Bluetooth
Hello all,
I was wondering how I could install the Bletooth option myself on my 2011 Camry LE. The radio display shows where I can see text an all and the speaker above the rearview mirror is there but the sales person said the car didn't come equipped with it so I would have to have it installed for over $370.00. I have th apart number as 00016-00097. Is it hard to do?
Old Oct 12, 2012 | 02:41 PM
grizlbr's Avatar
Thumbs up Their job is to get you into shop!
While checking my ECU voltages I found a connector with 5 wires on one side and 7 on other. If your radio shows the option the connector is part of the wiring harness: not a different harness for BlueT. So behind the radio is the wiring how difficult to get there? And how comfortable are you at pulling the radio to get to the connector? Is there a small hole at each corner of face plate? If yes it may be similar to Ford and need two pieces of coathanger bent into a "U" about 6 " deep. Hope that gives you some info. It should be plug and play.
Old Nov 11, 2012 | 07:46 PM
Elgman's Avatar
Hello my friend, for a few dollars more, you can purchase a dvd, gps and navigation system comes with blue tooth and installed it yourself, "plug and Play" using factory wire harness, your steering wheel control works with it also, fits exact in factory slot, I just installed one this weekend.
Csmithett
Jun 28, 2011 08:10 PM
jambalaya70
May 18, 2010 10:29 AM
morleybc
Mar 19, 2010 08:43 AM
cardvd4u
Jun 6, 2009 10:49 PM
