2AZ-FE Ignition Coil electrical harness clips
If any of you have broken off the ridiculous tabs on the coil electrical harnesses, like I did working on all these issues on my ride, the dealer part number for the replacement connector housing is 90980-11885. My dealer wants $11.93/each, but Camelback Parts has them for under $6/each:
http://parts.camelbacktoyota.com/par...&siteid=214329 Just FYI. |
Could you post that link again, please? The link didn't work.
Sure, see if it works this time:
Toyota Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping Basically you can go to parts.camelbacktoyota.com and search for part 90980-11885. I've seen other posts on other forums about this that state other sites have them for about the same price. |
And to be clear, you are talking about that plastic tab that snaps off of the coil where the wire connects, right? If that's the case, I need to order two as I have them kind of wedged so they won't come off!
Thanks for the link, I thought I would have to buy the whole plug/coil assembly and not just the housing. |
Originally Posted by Patonium
(Post 88133)
Cool. Again thanks and I look forward to your video.
I ordered the replacement parts last week, I believe they are in at the dealer. I should have a video up by this weekend showing the replacement.
Nice, I'm looking forward to it as it is something that I should fix on my car.
I have them in my hand, got my laptop in yesterday and tested my borescope on it (works perfect), and loaded my Chinese Techstream clone. AWESOME. Sooooo, lots to post up in the coming days:
video of changing the clips video of pre-Kreen soak on the piston tops and valves (think I will remove the cover and scope to the valves to get a baseline then again after I soak) video of the software in action Good days. |
Looking forward to it!
