91 2.2 GL compatibility
I have a 1991 Toyota Camry 2.2 GL. It was purchased in Europe.
Rockauto.com only sells parts for the 1992 Camry GL 2.2. They are also marked USA/Canada.
Does anyone know if all the 1992 parts are compatible with the 1991?
Toyota made a HOST of Camry variations marketed under a number of names for world wide sale.Trying to keep them all straight is a challenge.
The Camry GL was stated to be totally redesigned in 1991. Then another major model change was in 1996. These year range corresponds to what was called a wide body chassis labeled XV-10. If this is true then 92 parts should fit a 91 with a few exceptions. Toyota makes major model changes every few years and in between does minor cosmetic changes.
Suggest you confirm the above by checking at UK Toyota forums sites as below:
https://www.toyotaownersclub.com
club.autodoc.co.uk
club.autodoc.co.uk
