92' 3SFE Camry No Spark
any help on how to test ignition coil especially with ohm readings and specs ?
ive tried grounding spark plug to engine metal head ( shows no sign of spark,was able to see it working prior no spark ), also check the voltage going towards the Igniter ,receiving 12 volts in all connectors . thanks in advance
ok so i got the coil tested, it read 0.28 ohms between primary and 12.46k ohms in secondary(both cold) ,is it time to replace? ,how do you find the pick up coil if i may ask? or is there even one.
