93 Camry A/C problem
Old Mar 11, 2021 | 04:15 PM
Wilkoester's Avatar
Default 93 Camry A/C problem
The air flow for my heat and Ac only comes out of the defrost and side vents.No airflow out the middle vents.Is there an actuator that controls the direction of the airflow?Where is it located? Any help would be greatly appreciated!
Old Mar 11, 2021 | 09:32 PM
An air duct comes out of the blower motor housing then splits off 3 ways to the front and side vents. There are center vent and side vent dampeners have servomotors to open and close the dampener doors. These center vent motor appears to have failed.
Access to the motor is under the dash. Here suggest you get some kind of service manual, search for Youtube videos, etc. You can then test the center dampener motor by applying 12v and if necessary replace it.
Kory Threatt
Mar 3, 2021 09:16 PM
Gen3Guru93
Nov 7, 2012 06:06 PM
coachie
Oct 2, 2008 12:58 PM
sdjtzwfl
Feb 7, 2008 05:04 PM
mnsynclvr
Nov 6, 2006 10:41 PM
