96 camry
Old Mar 8, 2012 | 07:40 AM
rcguy's Avatar
Default 96 camry
My tail light indicator light on my dash comes on,but not all the time.But all the lights work.Any help would be great.
Old Mar 8, 2012 | 09:51 AM
Determine if the light comes with braking, brake and tail lights are monitored by the indicator system.
The indicator can light up even if all bulbs work as one may be failing. Try changing all bulbs plus inspecting the bulb socket for corrosion.
Also check wiring between chassis and trunk lid for damage due to flexing.
Old Mar 8, 2012 | 11:27 AM
rcguy's Avatar
Thanks for the help
Old Mar 8, 2012 | 09:39 PM
full house's Avatar
also check the wiring details of the light indicator if its connected properly
Old Mar 9, 2012 | 12:37 PM
Gen3Guru93's Avatar
I had a 96 camry prior to my 93. It had the very same problem. Never knew what it was.
