99 Camry automatic must put in N to start?
Hello,
I actually paid for that response at "Just Ask.com" to find out where it was and a Toyota mechanic sent me that illustration. I still couldn't find it. I was hoping you would have better luck. I only looked from under the hood.
If you go onto Autozone.com they have a nice website that gives pictures and even try to help you with illustrations for installation of some parts. However, the illustration that they give for the neutral safety switch is a generic one (not for Camry). Below is a photo of the switch. I finally took my Camry to a mechanic and he determined it was the starter motor. I was only getting a single click when trying to start until I moved the shifter back and forth to get it to start. Finally, I couldn't get it to start. When I called the mechanic, he suggested turning the ignition on and off rapidly several times. This WORKED! Also, suggested tapping the started motor with a hammer. If it's the starter, this may work.
Good Luck,
Bob57
Good Luck,
Bob57
Shadowen925
Oct 19, 2013 03:41 PM
babyboigsxr
Mar 15, 2007 09:12 PM
