Additives for Manual Transmissions that use ATF
Old Dec 2, 2019 | 09:51 AM
MagicWrench's Avatar
Default Additives for Manual Transmissions that use ATF
Hi,
I have a 1990 Camry 2.0 4cyl with a five speed manual transmission. The factory spec fluid is Mercon/Dextron Automatic Transmission Fluid, which is what I put in it It makes some noise, leaks a bit, and is rather old and so I want to try out a transmission additive, Xado Revitilazant and Lucas Transmission Fix to be specific. But I'm unsure which products are appropriate since although the transmission is manual, the fluid is ATF. I can imagine that the main factor in making an additive is that it is appropriate for the kind of fluid int he transmission, which inclines me to think that I should buy additives that are for an automatic transmission. Does anyone know what additives are appropriate for my transmission and why?
Thanks.
konamo
Feb 11, 2019 03:10 PM
1989_Camry
Sep 13, 2018 12:06 PM
hardyrxp
May 5, 2015 08:38 PM
indiglofish61
Apr 29, 2015 04:41 PM
melahi
Jun 20, 2008 09:49 AM
