exterier door handles 96 camry le
Old Dec 5, 2017 | 10:31 PM
camrydiez's Avatar
Default exterier door handles 96 camry le
mine all broke except one and it was a used one i bought at a wrecking yard for about 30 bucks. is this normal?
Old Dec 6, 2017 | 12:09 PM
They do break.
Old Dec 17, 2017 | 06:23 PM
wdc123's Avatar
I had one break on my 1995 Camry but some folks are a little brutal on these.
Old Feb 26, 2019 | 08:27 AM
jazzman5351's Avatar
I have a 98 camry le which I relaced all four door handles. The drivers side really gave me a hard time but I got it off and put in the new one. I broke the passenger front handle a few weeks ago when it was so cold I couldn't open the door. Lesson learned. Also a note, if you buy new handles like I did, you have to buy new bolts cause the original wont fit. But you say you got yours at a junk yard so that shouldn't be a problem for you. Good luck!
Old Feb 27, 2019 | 08:44 PM
wdc123's Avatar
Drivers side was a pain. I share your pain on that one. In fact I cut out a small section in the metal to get at removal. 1995 Camry XLE.
Old Feb 28, 2019 | 09:03 AM
Default Re: 98 Camry Door Handle
well lucky I didn't have to cut anything other than my arm which got banged up while doing this, part of the process of DIY I guess. I had to go to Lowes to find the right bolts because the one I used was a screw in type and it's too loose. So in short I have to get back in there and replace the bolt. I'm just waiting for it to get a little warmer. I thought of doing it this morning but it was so damm cold I decided not to tackle it. I just have to be careful when I do open the drivers side door until I finally complete the job.
camrydiez
May 29, 2017 08:04 PM
MikeMP
Sep 12, 2012 02:56 AM
sjmacdonald56
Dec 2, 2010 10:56 AM
stormy76
Jul 20, 2010 06:40 AM
ezekielguy86
Feb 22, 2008 11:17 AM
