Fogs on 09 hybrid
Old Dec 31, 2015 | 08:34 PM
Char92's Avatar
Talking Fogs on 09 hybrid
Lookin to put some OEM style fogs on my 09 hybrid.
before i pull the trigger on a set from ebay i was wondering what the best
way is to wire them in, besides using the switch it comes with. I cant really use the switch it comes with because i dont have an open spot on the dash, and i really dont wanna make a hole. so whats some other options. id like them to come on and off with the low beams. Thanks in advance.
Old Dec 31, 2015 | 10:13 PM
dirty hands's Avatar
you need to work out if the low beam OEM fuse and wiring and relay will take the fog lamps full draw when they are on
would this work for you
I would use an inline fuse on each power side of the fog lamp for safety
wire each power wire of the fog lamp into the power side of the low beam on each side of the car
and find each side ..an earth point on the chassis of the fogs earth wire .
.that makes the circuit when you turn on the low beams
Old Dec 31, 2015 | 10:21 PM
Char92's Avatar
so that would mean cutting the factory wires, correct?
Old Jan 1, 2016 | 02:23 AM
no dont cut any wires
I use wire traps Figure 6 in the link below .
.you can find these connectors for sale almost any where in your local area
australian link used only for identifying the product .
Joiners/Wire Taps - Products - Narva
position the wires you want to join .... in each slot side by side ..not stripped back at all
...close together the wires in place ... the metal trap jaw...... with wide pliers
clip the flap in place
connection made
insulation tape all around the trap if you like more water proofing
Jack in Norfolk
Jun 7, 2013 03:57 PM
Camry84
Nov 3, 2011 05:03 PM
peternguyen504
Oct 30, 2009 12:33 PM
bujudar
Jun 28, 2006 11:36 AM
