Power Steering Flush?
Old Oct 18, 2022 | 04:37 PM
hippieelmo's Avatar
Default Power Steering Flush?
I took my 98 inline 4 Camry to differnet shops asking them to flush the power steering fluid. Both shops wouldn't do it, one of the shops told me that all you need to do is check the fluid level and add ATF if it is low.
Do you need to flush the power steering fluid? Car has over 120K on it.
Thanks
Old Oct 18, 2022 | 10:38 PM
No need for a flush. Just remove and refill the PS reservoir a few times until the fluid is clear again. Drive between refills to circulate the new fluid. There are cheap hand pumps that will draw out the old fluid.
PS uses Dexron III which now now goes by various names such as Mobile AFT.
Old Oct 29, 2022 | 12:57 PM
hippieelmo's Avatar
Just did the 1st removal and refill yesterday. Going to check to see what the color is of the new fluid. Old fluid was dark black
Old Oct 29, 2022 | 03:15 PM
Should clean up pretty fast with a few reservoir changes.
mgwhiteman
May 13, 2022 01:16 PM
WDJ
Apr 23, 2021 08:48 AM
purecopper
Aug 9, 2009 09:36 PM
melahi
Jun 20, 2008 09:49 AM
wdbettis
Apr 4, 2006 04:05 AM
