Radiator Neck Adapter Doesn't Fit (Off-Camry)
Old Jul 19, 2018 | 07:32 PM
1989_Camry's Avatar
Default Radiator Neck Adapter Doesn't Fit (Off-Camry)
I have a 1996 Tercel that Amazon says Stant adapter 12025 fits on the radiator neck such that I can pressure test the cooling system.
The adapter does not fit my radiator, but the corresponding 12024 fits the radiator cap perfectly. Specifically, the 12025 fits on the pressure tester, and sits, but does not thread tightly, on the radiator neck.
I have the appropriate radiator cap and radiator neck adapters for my 1989 Camry (#12021 and 12027), and I know how to set up the adapters and pressure test
Any thoughts as to what's wrong?
Old Jul 19, 2018 | 11:33 PM
Did the unit come with multiple o-rings to add/remove to get the right fit?
Old Jul 20, 2018 | 12:45 AM
1989_Camry's Avatar
Thanks.
No. It was only solid piece of metal:
Amazon Amazon
That's the same shape, without adapters, that fits perfectly on my 1989 Camry's radiator neck.
Do you think that this kit will work (chrome object being the o-ring you're referring to)?
Amazon Amazon
Old Jul 20, 2018 | 05:11 AM
Does the "solid" unit have an internal spring to compensate for clearance differences and allow a tight seal?
If no spring, the addition/removal of rubber washers adjusts the seal.
Read the customer comments about this product at your first Amazon link.
Old Jul 20, 2018 | 09:48 AM
1989_Camry's Avatar
Thanks.
The adapter is without springs and did not move.
I understood everything in that review except: "...This new type you have to remove rubber washers one at a time until it fits the radiator without leaking..."
By "rubber washers," do they mean in the center of the adapter?
However, that same side that connects to the radiator neck has two notches without tapering on the notches or the other areas on that side.
This is the silver version of the black version that I have:
https://guideimg.alibaba.com/images/..._21105260.jpeg
Finally, would this kit work, or is it missing the radiator neck adapter?
Amazon Amazon
Old Jul 20, 2018 | 01:07 PM
The adapter you have appears to be for 35 x 10 mm deep cap. There is another adapter for a 35 x 16 mm deep cap.
See link:
Amazon Amazon
The link below lists Stant products:
http://www.stant.com/files/3514/0979...r_Adapters.pdf
Old Jul 20, 2018 | 03:09 PM
1989_Camry's Avatar
Thanks. I now understand that #12025 is 35 x 10mm and that's why it won't fit.
I don't see the adapter that is 35mm ID and 16mm deep. What's the part number?
Old Jul 21, 2018 | 11:30 AM
See link:
Amazon Amazon
Look on page for part number 12027 listed in Frequently bought together.
Old Jul 21, 2018 | 08:15 PM
1989_Camry's Avatar
Thanks. Amazon says that won't fit my car.
Old Jul 21, 2018 | 10:17 PM
Read the info at the Stant site link:
The 12024/12025 adapters are for a 31 mm x 10 mm cap/cooling system as used by Tercel.
The Camry cap/cooling system is 16 mm x 35 mm.
The 12021 adapter is stated to be for a 16 mm x 35 mm cap. The 12027 for the cooling system.
