right front bearing carrier problem??
Old Jun 13, 2010 | 12:02 PM
camrywilder2's Avatar
Default right front bearing carrier problem??
hey, trying to change a right front cv axle, but the i can not get the axle's carrier bearing out of the mount on right side of my 2003 v6 camry.. does anybody have any ideas?? I was thinking of using a little heat or maybe a bag of ice place around the carrier???
Old Jun 13, 2010 | 04:37 PM
Did you remove the bolt and snap ring on the bearing carrier mount?
Old Jun 13, 2010 | 05:00 PM
I did remove the snap ring and the bolt, but that bearing on the axle does not seem to come out of the mount....
Old Jun 13, 2010 | 05:44 PM
If the clip and bolt are removed and the shaft is stuck, the carrier bearing outer housing (for lack of a better word) can freeze to the mount due to rust and corrosion. This problem is not uncommon.
You can try using penetrating fluid, hammering, etc. Some have removed the mount to work on the assy at their shop table.
Suggest an internet search on possible solutions, again this is a reasonable common issue. One that be extremely difficult to deal with.
One owners solution was to just replace the outer portion of the shaft and CV joint.
Heat would work but would need a torch to get the mount really hot.
One other site to try for suggestions is the Toyotanation site.
jbundy321
Jan 6, 2015 09:58 AM
FERGI
Mar 25, 2011 05:04 PM
E_S
Jun 20, 2008 02:13 PM
redmartin
Mar 5, 2008 10:03 AM
jbishop1
Aug 20, 2007 12:50 PM
