Snapped a random wire
Old Mar 12, 2021 | 05:21 PM
goldenphoenix's Avatar
Default Snapped a random wire
While doing a small repair on my 2000 Toyota Camry LE, I snapped off an electrical wire (see picture). What wire is that and what is the easiest fix?
I'm pretty much a noob at DIY. Any help will be appreciated.
Old Mar 12, 2021 | 05:43 PM
Oil pressure gauge.
Got a soldiering gun?
The metal female electrical connector in the plug can be removed. Solder the connector to the wire and reinstall it into the plug..
Or search for a replacement female connector and connect to the wire.
Find junk yard care and cut plug off with a section of wire.
Solder the wire directly to the male electrical connection on the pressure sensor.
Old Mar 12, 2021 | 05:53 PM
Thank you! I will probably do it the first way. I don't have a solder gun - looks like I will need to get one. Is it okay to drive my car short distances in the meanwhile?
Old Mar 12, 2021 | 05:55 PM
Also, would some insulation tape suffice to hold the two ends together? I don't have much experience with soldering.
Old Mar 12, 2021 | 08:05 PM
Tape might work if you get the kind that is self adhering, see link below.
https://www.google.com/search?q=self...t=firefox-b-ab
Clean the end of wire and the flat blade connector of the sensor for good electrical contact. Try to mechanically attach the wire to the connector (wrap the wire around it) then wrap with the tape.
There are also electrical conducting glues.
Old Mar 12, 2021 | 08:39 PM
Great idea! Thank you, really appreciate your help.
Feb 19, 2021 12:10 AM
chuttney1
Mar 2, 2019 10:52 AM
onefineassguy
Jan 31, 2019 06:04 AM
septicdeath
Apr 1, 2008 08:37 PM
tik05
Feb 28, 2006 02:48 AM
