Old Aug 26, 2015, 01:01 PM
How-Tos on this Topic
Browse all: Exterior Guides
Print Wikipost
Windshield wiper broken
Old Feb 8, 2011 | 05:19 PM
built2burn's Avatar
Default Windshield wiper broken
99 camry (gen4)
i dont really know the terminology for windshield wiper assembly so i sure what i need. it was 8pm and a blizzard. i know i lost the pin but a piece is broken and i dont know what it is or how to fix.
the passenger side windshield wiper broke where the pin connects to the base of it.
wiper arm -> spring thing -> pin -> broken piece (pictured
and this is whats left
does anyone know where to buy replacement parts or any advice to repair would be greatly appreciated. let me know if you need any clarification
Old Feb 9, 2011 | 12:32 AM
Does the wiper that is NOT broken look kind of like the wiper arm in the link below?
http://www.partsgeek.com/mmparts/win...ota/camry.html
If so this is called a wiper arm. It connects to a splined shaft protruding from the car body. The shaft rotates and this moves the wiper arm.
You need to obtain a replacement are as replacement parts are not available and this one appears unrepairable.
An auto salvage might have a used one, auto part store or the Toyota dealer can get one in a day or so if not already in stock. Call around, ask for a wiper arm fitting your make, model and year of car and the side of the car that has the broken part (drivers or passengers side as the two arms may be different). It is easy enough to replace, where every you get the part ask how to remove the old one and install the new one.
Old Mar 9, 2011 | 04:27 AM
jackgem's Avatar
The crank arm on your wiper motor is a complicated little assembly which allows the wipers to "park when you turn the wipers off. It does this by lengthening when on and shortening when off. As a by product of this, it is a little bit fragile. Yours broke from wear and tear or because one of your wiper arms came loose on its pivot.
jmcolwell
Jan 24, 2012 10:01 AM
boogz
Jan 11, 2010 11:05 PM
952DRCamry
Mar 22, 2009 11:49 AM
Player
Dec 3, 2008 06:03 AM
Player
Nov 27, 2008 01:17 AM
