2000 camry evap check engine code
Old Dec 21, 2005 | 12:57 PM
samandjen1's Avatar
Default 2000 camry evap check engine code
This SES light keeps coming on, we had the evap purge sensor replaced. Code stayed off for a while now its back on. Does anyone how to fix this or by pass the sensor? I dont want to drop $90 every couple of months.
Old Dec 23, 2005 | 02:14 PM
Patrick's Avatar
Administrator
Default RE: 2000 camry evap check engine code
so it was scanned, and a gross evap leak came out?
Old Feb 1, 2006 | 11:11 PM
csaxon's Avatar
It may be another problem. What was the original code? Get it scanned again to get the new code.
Purge sensors are rarely bad. Your model year has problems with VSV (vacuum switching valves) at the charcoal canister. Also, there was a defective vacuum hose associated with it. Toyota has corrected the manufacturing defect and updated both parts.
Old Feb 3, 2006 | 04:38 AM
trdcamrygracia's Avatar
do u know wuts the part # for the vacuum hose...i got the vsv but the cel still pop up...and same code
Old Apr 20, 2006 | 12:59 AM
OnE_To_HatE's Avatar
some codes are similar, make sure you don't mistake them for other codes as well. My gen4's Check engine light came on and it read out an evap code, but it was the o2 sensor??... take a second opinion?
Sugio
Apr 2, 2013 03:17 AM
sconley
Mar 2, 2012 09:33 AM
ac2011
Nov 27, 2011 11:12 PM
AppleGirl
Dec 22, 2008 03:50 PM
hewber
Nov 28, 2007 05:25 PM
