2007 Toyota Camry
Old Jun 30, 2025 | 08:54 PM
jrsvette's Avatar
Default 2007 Toyota Camry
I have a 2007 Camry that the door locks and dome light and the fog lights and key minder are not working. My tech is thinking it is the Body ECU but I would like to know before spending 1000 dollars.
Has anyone come across a problem involving the Body ECU?
Old Jul 1, 2025 | 06:21 PM
Might try Toyotanation.com for another opinion.
All those items are controlled by the body ECU.
The tech should be able to test if the body ECU is working or not for most of the individual items you listed. This is in generating a signal. Typically, the ECU functions by grounding an electrical circuit to turn on a relay or complete a circuit.
If bypassing the ECU to turn on the fog lamps has them work, then this leaves the ECU or its control switch as a possible issue. The fog lights are good start as the relay is located in the engine compartment and can be easily bypassed.
The non-working items may have common ground wire points to chassis. A bad ground can cause all sorts of electrical issues.
DanielAndrew
Oct 18, 2023 01:57 AM
DanielAndrew
Sep 16, 2023 02:24 AM
Dylan07
Aug 18, 2019 06:00 PM
Michele Govan
Mar 26, 2017 02:04 PM
thsiao
Jan 25, 2007 03:20 AM
