Codes P0135, P0115 '94 V6
Old Nov 8, 2012 | 10:16 AM
gabegallear's Avatar
Default Codes P0135, P0115 '94 V6
'94 Camry V6 XLE
Got my CEL read today at O'Reilly's. Came back with:
P0135 -- O2 Heater Circuit Bank 1 Sensor 1
P0115 -- Engine Coolant Temperature Circuit
Here are the symptoms of misbehavior on this car:
The dash temperature gauge reads very hot. The radiator, thermostat, and the coolant temperature gauge have been replaced. I brought the car to my mechanic to replace the water pump too, but he used the infrared temp. reader to determine that the cooling system was operating at the proper temperature. The problem is somewhere in the wiring.
Also, the engine tends to hesitate and chug (like the mix is off) when the engine is cold. Once the engine heats up it accelerates fine.
Obviously, I need to replace an O2 sensor. Where is bank 1, sensor 1? What do I do about the coolant temp circuit?
Thanks in advance!
wolfdog2
Nov 28, 2012 09:46 PM
TomForsythe
Nov 16, 2007 05:37 PM
mrmikewilson
Jan 3, 2007 09:35 PM
idahoruss
Nov 25, 2006 10:39 PM
jlaley
Apr 9, 2006 11:10 PM
