Connector Question
Old Jun 4, 2008 | 03:10 PM
wtroger's Avatar
Default Connector Question
Can someone tell me where pin 10 of connector IP1 goes/does
Old Jun 4, 2008 | 03:19 PM
Default RE: Connector Question
What year/model/engine and trans type?
Old Jun 4, 2008 | 09:37 PM
wtroger's Avatar
Sorry brain Fart 1993 toyota camry 4 cyl automatic
Old Jun 4, 2008 | 11:58 PM
Info I have has no IP1 with 10 connectors.
Where is this plug located in the car, what is the pin layout (as in stacked up, 10 pins in a line, etc)? Wire colors going to plug?
Old Jun 5, 2008 | 06:53 AM
wtroger's Avatar
It is a 20 pin white connector attached to the blower housing under the glove box it is the left one. it has a black with a red stripe wire in it it goes to the starter solenoid. The question is the black wire at pin 17 is what is coming hot when the ign swich is turned to start and nothing is going to the pin 10 wire that goes to the starter.
Old Jun 5, 2008 | 10:39 AM
Appears to be optional ABS system manufactured by TMM.
Pins are labeled left to right starting across the top. Then drop down and again go left to right, etc.
Pin 9 would be blank (in center of the plug), Pin 17 is just below Pin 9 (there 2 pin connectors are in center of the plug).
Power wise: the Black/Red wire goes to the ECU-IG fuse and would be hot when the ign switch is on. The White/Blue runs to the ABS fuse, but if no ABS you will not have this fuse. Green/White wire runs to the brake light switch.
yert42
Jun 7, 2009 08:38 PM
CDU1MALE
May 28, 2009 12:46 PM
mjnrite1
Aug 23, 2008 04:33 PM
NorthWet
Jun 8, 2007 01:08 AM
gijsen
Apr 9, 2007 02:36 AM
