Old Aug 26, 2015, 12:09 PM
How-Tos on this Topic
Browse all: General Overview
Print Wikipost
Homelink
Old Sep 5, 2007 | 08:58 PM
h1_vltg's Avatar
Default Homelink
Anyone know if the overhead homelink from a 2007 Camry Hybrid is a direct plug in for a 2007 Camry SE. I imagine it would be, but I could be wrong.
Thanks in advance!
Old Sep 6, 2007 | 12:05 AM
toyoboy's Avatar
Default RE: Homelink
they should be the same but to make sure i would call thedealership and ask.
Old Sep 6, 2007 | 12:43 PM
h1_vltg's Avatar
1st Dealership couldn't help me...I'll try calling another.
Old Sep 23, 2007 | 08:38 AM
w5mec's Avatar
If you happen to find out a definitive answer, please post back. I'm looking to do the same to our 07 Camry LE (w/moonroof).
Thanks,
-Me
Old Sep 23, 2007 | 05:34 PM
w5mec's Avatar
Default Re: Homelink
OK, here's the scoop on my 07 Camry LE (w/moonroof). I bought an overhead console that included moonroof controls andHomelink off of eBay...gambling that the LE model would have the necessary wiring and electronics already in place. New (to me) console showed to be out of an 07 Camry Hybrid. Interior code onour LE is FB40 (fabric interior, bisque color). The Hybrid that the new console came out ofhad interior codeLA40 (leather interior, bisque color).
Well, the console arrived late last week. Color matches perfectly. Just finished pullingtheLE's original console to have a look around. Hmmm, there is (or was)a wire tucked away under the headliner off to the passenger side of the car...had some foamwrapped around it to keep things from making noise I suppose. The plug isa 5-pin unit, but only has 3 wires (hint) attached to it -- onewire inthe middle and one wire on the far end of each side. I pulled it out and had a look. Sure enough, it's the wiring for the Homelink system! Plugged in the new console and gave things a whirl. Everything worked and the Homelink buttons "lit up" when pressed. Woo hoo!
Looked around on the 'netfor some Homelink programming instructions. Programmed it up and mated the systemto my garage door opener. Works like a champ!
Thiswas a simple 15 minute R&R operation (minus the interior light fuse I blew when I accidently shorted things while pulling the connectors apart). Hint: Either disconnect the battery or removethe interior light and moonroof (if equipped) fuse(s) before pulling the console!
Can't speak to the SE or CE models...only the LE. I'd say pull your console and look for the tucked away wire described above. If it's there, then you may be all set for a simple R&R upgrade.
-Me
RKILPA
Dec 27, 2020 02:19 PM
jwthomas
Jul 23, 2008 03:07 PM
MaximaPower
Oct 23, 2006 06:54 PM
