Need power for my tush!!
Replaced my seats in 95 Camry LE.
All from a Camry in the Junkyard. Mine were Faux leather and thess are cloth. With one exception, the driver seat is power.
Need input on how to wire.
Tried the Red W/ white stripe in channel on driver side. No dice. I can move seat with a battery no problem. Trouble with actual spot for wires. Fuse panel?
Thanks for any input.
Thinking about adding a moon roof next!!
any input there?
Thanks all!!
any input there?
Thanks all!!
The power seat would get power DIRECTLY from the 30A Power fuse located in the fuse panel on drivers side of instrument panel behind ash tray/coin box.
Power fuse powers indirectly powers the windows by a relay. Look for a blue wire going up the center chassis pillar from the bottom. This wire will only have power when ign key is on or ACC. Not sure if this relay switch can support the seat and windows at the same time.
Thanks !
Thanks! Will give that a go!
