stupid codes!!
Old May 8, 2014 | 08:46 PM
1965 camery's Avatar
Unhappy stupid codes!!
had battery out that's it.. that smaller wire on the positive battery cable broke off. I put a new end on all good. This morning p0138 02 sensor hi voltage bank 1 sensor 2 p0606 pcm processor fault!!its a 2005 and I just got it yesterday.
Old May 9, 2014 | 11:00 AM
What engine, V-6 or 4-cylinder?
Old May 9, 2014 | 02:24 PM
sorry 4 cylinder
Old May 9, 2014 | 04:32 PM
If the electrical problem is fixed, clear codes and determine if they recur.
If both codes return, work on the P0138 code first.
Bank 1, sensor 2 is second sensor on exhaust system coming off cylinder head.
Old May 9, 2014 | 07:36 PM
thanks for your help!! sure is nice to have a Camry community to help out. Im guessing the o2 sensor is causing the pcm problem?
Old May 10, 2014 | 10:52 AM
For these two codes and this model, typically yes. After sensor repair have ECU reset.
When fixing sensor, check for issues of road water, damaged wiring, etc, for sensor wiring and plug. A short caused by too much road water getting into sensor wiring/plug may cause this code.
If fixing the care yourself. Get the correct sensor (there may be many listed), one that is not universal (wiring is user adjustable to fit more then one model) and suggest Denso or Toyota brand. Other brands may have problems in Toyota.
Old May 10, 2014 | 02:23 PM
Thanks again for the input.
wolfdog2
Nov 28, 2012 09:46 PM
LeeMooNia
Jul 28, 2009 09:40 AM
TomForsythe
Nov 16, 2007 05:37 PM
idahoruss
Nov 25, 2006 10:39 PM
jlaley
Apr 9, 2006 11:10 PM
