02 4cyl. loses power after it warms up
Runs normal until warmed up then loses power and feels like it's not firing on all cyl. If you press down on the gas quickly it will surge from 0-2000rpms repeatedly or it will die but will start right back up. If you press the gas gently it will excell slowly but it starts to shake real bad at 50mph and won't go beyond that speed. I am getting cyl. 3 coil failure code so I replaced all the spark plugs, all coils, fuel filter and added "Heet" to gas thinking it might have water in it. No change. I can hear all the fuel injectors working.
knowthroughroad
Mar 18, 2011 04:58 PM
rt07
Jan 11, 2011 10:26 AM
