1995 Camry White Smoke out exhaust
Old Mar 8, 2019 | 02:06 PM
  #11
wdc123's Avatar
Maybe I should clean it
Old Mar 8, 2019 | 09:57 PM
  #12
Could be a number of reasons for the code.
When engine idling. Apply vacuum to the EGR valve to turn it on and determine if the engine quits as the result of too much rerouted exhaust.
Old Mar 9, 2019 | 01:22 PM
  #13
wdc123's Avatar
Ok, Thank you.
Old Mar 10, 2019 | 07:21 PM
  #14
wdc123's Avatar
Warmed up the car. Pulled the vacumn hose from the EGR port. Plugged the rubber hose.. Connected vacumn gauge to EGR port. Pulled vacumn ( 15 mm hg) and vacumn was steady but idle was rough and almost car almost stalled..
Old Mar 10, 2019 | 07:44 PM
  #15
wdc123's Avatar
Also code is P0401 flow insufficient. Double checked it with my reader at home. Got first reading from Autozone.
Old Mar 10, 2019 | 10:01 PM
  #16
If engine applying vacuum caused the problems listed, the actual valve seems to be working OK.
The issue may be the components that control vacuum to the valve. This being the modulator and VSV valve. VSV turn vacuum on/off to the EGR system. Modulator regulators vacuum pressure based on manifold pressure. The regulated vacuum pressure determines EGR valve position for more or less exhaust gas flow.
The VSV is powered by 12v. Can check operation.to determine if it is works.
See private message.
Old Mar 10, 2019 | 10:07 PM
  #17
wdc123's Avatar
Thanks
Old Mar 13, 2019 | 06:38 AM
  #18
wdc123's Avatar
I was driving the car yesterday and at a brisk pace which is not common since I am not a speedster. . After that the check engine light went off. Will monitor and troubleshoot further if needed. Strange.
Will also check for codes on the car.
Old Mar 13, 2019 | 10:26 AM
  #19
Don't know.
The EGR does turn off under certain driving conditions. One is full throttle.
Old May 21, 2019 | 12:32 AM
  #20
wdc123's Avatar
I was checking all the vacumn lines and connections just to start simple . Good shape and no dry rot but they are old so could be questionable. However, I noticed two vacumn hoses going into a tank closer to fire wall fender and the cover cracked right at where the vacumn hoses feed in(2). Directly below brake reservoir. Trying to figure out what this is.
