3rd gen motor swaps
Old Oct 25, 2011 | 09:54 PM
agifoto's Avatar
Default 3rd gen motor swaps
well i'm getting a 92 camry and i was wondering what motors are possible to swap into them. its pretty much just a fun thing to play with so any options you know of just let me know
Old Oct 26, 2011 | 08:23 AM
What engine model is in the car now?
Old Oct 26, 2011 | 12:19 PM
agifoto's Avatar
its got the 4 cyl in it now. 5mt. and its been ghetto-fied haha.
Old Oct 26, 2011 | 09:27 PM
A V6 would require a different trans but will fit (was an option). Don't think the V6 was offered with a manual trans thus more changes to the car would be required.
Not many performance upgrades for the current engine in the car.
There is a 3S-GTE turbo will fit, used in Celica and MR2.
The current model engine in the car can be turbocharged. This may be more common then the above swap.
Old Oct 27, 2011 | 11:25 PM
agifoto's Avatar
would those bolt up to the tranny though? and how much of the wiring do you think i would have to splice?
Old Oct 28, 2011 | 09:06 AM
All but the V6 would bolt up.
For an engine swap you would need to change the computer and wiring would be easier if the engine wiring harness changed.
Turbo charging the 5SFE engine may be easier route. Years ago a Toyota dealer was offering a bolt on kit for this engine.
Old Nov 2, 2011 | 07:53 PM
agifoto's Avatar
so i ahve the car now and its a 3sfe. thats what the gasket kit says... anything good come fromt that?
Old Nov 2, 2011 | 09:12 PM
agifoto's Avatar
and i figured out its a 91. not a 92. that probably makes a bit of a difference.... hahaha
oops.
Old Nov 3, 2011 | 08:35 PM
The 91 may have the smaller 3S-FE 2L engine. The larger 5S-FE replaced this, should bolt up.
Old Nov 8, 2011 | 05:17 PM
agifoto's Avatar
would the 3s-gte still work?
that would be better seeing it as a turbo'd factory motor.
