6.5 quarts?
Old Feb 20, 2007 | 12:56 AM
Virus's Avatar
Default 6.5 quarts?
Am I reading the manual correctly that the new 2k7 Camry takes 6.4 quarts of oil?
Old Feb 20, 2007 | 04:02 AM
nodrogkam's Avatar
Default RE: 6.5 quarts?
wow thats a crap load of oil! but if the owners manual says so...then it should be right.
if you're doing your own oil change you can just buy 7 quarts just in case, and just fill it with 5 first, and check to see if it even registers on the dipstick. if not, keep adding and keep checking levels.
Old Feb 20, 2007 | 05:25 AM
OnE_To_HatE's Avatar
If that's the 2GR motor- then yes but if its the 2AZ; i'd stick with 4. if you have the 2GR motor- that motor is ridiculously capable with a boat load ov aftermarket support just cuz its the base engine on the new IS. enjoy! hope this helps!
