97 camry still misfires and changing coils and plugs
Old Dec 29, 2016 | 03:59 PM
Dwosyk's Avatar
Default 97 camry still misfires and changing coils and plugs
I have a 97 4 cylinder Camry that developed a misfire and began to run more and more rough I had it scanned and it read misfire on 1 and 3 so I changed the coils and then the plugs and the problem hasn't gone away and I had it scanned again with the same results, had the codes cleared and they came right back. Could it be bad coils or could it be possible jumped time
Old Dec 30, 2016 | 05:15 AM
DatsunZebedi's Avatar
Maybe the fuel pump needs changing? Is there a buzzing sound coming from underneath the middle of the car where the fuel pump is?
Other idea is the O2 sensor.
Old Dec 30, 2016 | 02:12 PM
dirty hands's Avatar
go old school .. fuel, compression, spark
spark covered
suggestion .. a compression test on the four cylinders
what codes came back ?
Old Dec 30, 2016 | 04:43 PM
Could be something other the ignition system
Low fuel pressure (fuel pump)
EGR valve issues
Injector plugged
Compression (not common)
Valve clearance (not common)
Valve timing (not common)
Mass air flow meter
Engine coolant temp. sensor (reasonable common)
Open or short in engine wire (not common)
ECM (not common)
Pickup some service info and check the electrical items.
SNSHEVEY
Mar 8, 2020 09:25 AM
nwstehle
Jul 27, 2011 07:41 AM
johnnydinh701
Jul 18, 2010 05:08 PM
Erniel
Aug 13, 2009 05:34 PM
tramsey
Nov 5, 2008 10:07 PM
