Engine Swap on '92 Camry
Old Sep 23, 2007 | 11:23 PM
Malone2006's Avatar
Default Engine Swap on '92 Camry
I'm trying to do an engine swap on my 1992 toyota camry le. i threw a rod, so i'm replacing the whole engine/trans combo with that from a '93 camry, but i seem to have hit a speed bump in the process...
can anyone tell me how i can remove the halfshafts so that i can rip this sumbi*ch?
Old Sep 24, 2007 | 05:00 PM
toyoboy's Avatar
Default RE: Engine Swap on '92 Camry
im guessing you are referring to the passenger axle shaft..if so the shaft is held by a large clip and a bolt..remove them and the shaft should slide out..it mit be rusted on, so you mit have to muscle it out..
Old Sep 24, 2007 | 05:06 PM
Malone2006's Avatar
I am in fact referring to the axle shaft. i understand how to remove it from the transmission. my issue was with removing it without taking my wheels off. hope that help you understand my problem.
Old Sep 24, 2007 | 11:44 PM
toyoboy's Avatar
that is a problem....but if you are replacing the motor and trany..isn't easier to remove the wheels and lower the subframe with the motor and trany with it?
Old Sep 25, 2007 | 01:51 AM
Malone2006's Avatar
that's an issue for me. wont i have to compress the shocks to put my rotors back on and my wheels so i can roll my car from under the engine/tranny?
upjeeper
Oct 25, 2012 01:56 PM
carlos1787
May 23, 2009 05:57 AM
Aaron
Dec 9, 2006 04:18 PM
scotbot
Sep 12, 2006 09:31 PM
