View Poll Results: Are Camry Ignition System Problems Easier to Diagnose then other makes and models
Certainly less complicated
0%
About average
0%
More complicated than most
0%
Voters: 0. You may not vote on this poll
Looking for a Real Challenge? 96’, Toyota Camry, 2.2, SOFE, DOHC
Are you looking for a real challenge? I have just the car for you. See symptoms and repair list below to see if you can solve the puzzle.
History
While idling one day the steering wheel began vibrating and mild power loss occurred. Later in the day more prominent power loss until finally very little power. At one point while in Neutral the engine would not vibrate. Intermittent spark was present on 1 and 4. Although now the vibration is present consistently and there is no spark present on 1 and 4.
Symptoms
- Loss of power due to no spark condition on cylinder 1 and 4
- Engine vibration
- Sputtering exhaust*
- Oil Leaks
OBD II Codes
- P0301 Misfire on cylinder 1
- P0304 Misfire on cylinder 4
- Catalytic converter inefficient code
Visual Inspection
- Cylinder heads corrosion/buildup moderate
- Cylinder 1 oil on plug boot
- Oil running down back of head through gasket oil covering fuel injectors
Actions taken based on symptom
- Cat inefficient code:
- Soaked cat in dish soap and reinstalled
Engine Vibration:
- Replaced engine mounts
- Replaced all 4 shocks and struts
Oil leaks:
- Replaced cam and crank seals as well as oil pump seal and gasket
- Replaced Valve Cover gasket and sealed
Loss of Power:
- Replaced timing belt with timing light
- Compression test all cylinders at 180 PSI in 4 cranks and holding pressure
- Conducted Smoke Test for leaks and Sprayed Carb Cleaner around Vacuum System. No leaks detected.
- Removed EGR component and cleaned with carb spray.
- Removed air intake and cleaned buildup on throttle body and took apart the IAC and cleaned. IAC had a stripped screw so I had to hone it out to get it off. Tightened it back with only one screw, seems tight enough.
Spark:
- Replaced plugs with mfg. recommend plugs.
- Replaced wires
- Replaced distributor cap (firing order correct 1,3,4,2)
- Replaced ECM
- Replaced Ignition Coil
- Replaced CPS (Cam Pos Sensor)
- Replaced Igniter
- Alternator bench tested, OK
- New battery installed
Fuel:
- Fuel psi test 48 PSI
- Replaced fuel injectors (4)
- Replaced fuel filter under hood
Additional Work Completed:
- Replaced complete A/C system
History
Symptoms
- Engine vibration
- Oil Leaks
OBD II Codes
Visual Inspection
Engine Vibration:
Oil leaks:
Loss of Power:
Spark:
- Replaced wires
- Replaced ECM
- Replaced Igniter
Fuel:
While your at it. Make sure the high voltage wire from the coil is always firing and doesn't have an issue at locations 1 and 4.
The distributor receives high voltage from the coil. The rotor and cap distributes it. If the high voltage is getting to 2 and 3 ign wires and not 1 and 4. Look at the distributor.
carid
Nov 19, 2014 03:36 AM
MarkJulian
Aug 30, 2013 06:37 AM
NorthWet
Jun 8, 2007 01:08 AM
